Will this be updated for V8? I used this all the time in previous versions. It was awesome.
geposted Thu 22 May 14 @ 5:29 pm
V8 has random video transition in the options ;)
geposted Thu 22 May 14 @ 5:52 pm
oops pardon me. cart before horse. LOL
What about the auto-trigger of an ambient when an audio-only file is played? Are you working on that or someone else?
geposted Thu 22 May 14 @ 8:19 pm
Use Milkdrop, you can find Scotts plugin in the usual place, follow instructions in the milkdrop thread to install and set up in config to use it when audio only is played.
It will blow your socks off.
geposted Fri 23 May 14 @ 2:21 am
Or you can use Sonique or Slideshow :)
geposted Fri 23 May 14 @ 2:27 am
Sonique is dead - long live Milkdrop, lol.
geposted Fri 23 May 14 @ 2:42 am
the more the merrier I say...as it is..I copy the milkdrop twice,and the soniques...with the Gforce svp...but that might be to much for normal folks...he,he
geposted Fri 23 May 14 @ 5:41 am
Keep the crap out and get less system failures is what I say... lol
geposted Fri 23 May 14 @ 5:55 am
Tayla,you checked your transitions lately ...:P
http://www.virtualdj.com/forums/188716/VirtualDJ_Plugins/plugings_workin___not___.html
geposted Fri 23 May 14 @ 10:35 pm
I couldn't take anyone's recommendations seriously, I have seen you mention that some fx's don't or have stopped working on your machines yet work perfectly fine on mine, it is subjective and can only be linked when the same effect has identical causes on separate machines.
I keep my machines free of bloatware others do not and this is where a lot of problems arise.
geposted Sat 24 May 14 @ 4:09 am
like all ur transitions
geposted Sat 24 May 14 @ 7:00 am
edit...
geposted Sat 24 May 14 @ 4:37 pm
misintrepation.I did the list in a hurry as I actually activated them and wrote down the results. now I see that if we open the Gui on many they do have controllers,but some dont.there is only a few that give no picture at all,and many that scott made with a mirrored image.these I know he will get to these anf fix them soon. I posted effects that I and therefore many others,have collected from this site over the years.now many of those could be still available at the downloads,did'nt check.the idea is that the list is there for reference.if you have a basic system setup so be it.I tend to experiment with video & audio before the virtual worl came up with their versions...therefore naturally Im going to cross the line...enough sayd.
geposted Sat 24 May 14 @ 4:46 pm
