Topic: Problem with icons
I have a problem with any of the skins vdj. The icons look blurry. No matter the resolution that uses the same happens. The text looks good, it's just with browser icons. Here are some pictures I took with my cell
My pc: Hp Envy Beats Edition I5
geposted Thu 22 May 14 @ 8:31 pm
I took a screenshot so that it looks better my problem
Do you mean the buttons like playlist/ sampler ect. at the right bottom and the browser buttons at the left...?
Same issue with all V8 Skins...?
EDIT: Ah..now i see....wicked...stay tuned...will give dan a call...
Is this with every skin, or just one?
If with all I seem to remember another thread that mentioned adjusting a graphics card setting.
I'll hunt it out and post the link.
It is with all skin even with the original skin
just adjust your intel graphic card setting to "quality" and you are golden ;)
move slider to right for the 3D setting
ah.. harrystone already posted .. ;)
Looks like everyone beat me to it!! lol
Did that work though?
It worked perfect. Thanks!
The solution worked perfect for me as I had similar problems, thanks
What's the solution with us on Mac's? We don't have an option...
on mac try this :
settings -> display -> resolution : best for display
That's the way that all of my Mac's are configured. (That option is a resolution setting, not a quality setting.) All of them have Intel 4000 or 5000 video adapters.
Same problem with MBP 13'' with 1280x800 resolution
