Forum: Wishes and new features
Topic: Sampler - Wishes & new features - Page: 15.15
Upgrade the sampler part with quantize and Snap options, mute vocals, mute melodies and mute kick. Editing gives precise audio,
Basic beat sequencer with at least 4 options: Kick, Clap, Hat and tones, combined with stems, expanded the live creation of remixes and mashups
https://www.facebook.com/share/r/UWL6sF62F6DPKHQP/?mibextid=D5vuiz
Using the Pioneer XDJ-XZ. So you can set the Beat Loop pads to be sampler pads by hitting Shift Beat Loop button. Unless I'm missing something, the samplers get triggered, but they do not light up and blink when in use like Serato does. Is their an existing setting to make this happen, or can we update the software so that the pads light up when their is a sample in the bank?
DjAkuAKu wrote :
Hello there.
For the sampler it's more than necesary to have a full volume control when we use a external pad with sliders or knobs.
I mean, vdj is unable to keep in memory the sliders volume positions when we opening the software.
Please, do something :)
VDJ does remember each volume. It's just the volume/gain you set in the sample editor
The reason is that the volumes in the sample overview are for for the sample position in the bank - so shared with the next bank you load - and is supposed to be able to change with each triggering, because it's supports touch sensitive pads
So for your purpose, simply set the sample volumes on each sample in the sample editor
A new sample type, for 1 shots you want to loop [bear with me hear].
I've got a load of kicks with long silent tails, I want sync loop them, but I don't want to pitch them.
Could the loop length be dynamically set at run time based on the bpm of master?
A side idea I worked on for remix skin is/was, using silent sync'd loops on the deck and that has apoi to call the one shot, it worked in principle but was a bit janky for full time use.
+1
sample editor to have a key parameter, maybe even something that could be changed on the fly with script that is reset to bank spec on bank change
sampler_key SAMPLENUM ±X
sampler_key SAMPLENUM ABSOLUTENOTE
sampler_harmonic SAMPLENUM ABSOLUTEHARMONINC
Seria ótimo se nos bancos de SAMPLERS tivesse um tipo TALK-OVER AUTOMÁTICO...igual o que já existe para microfones.... ao clicar nos PADs de SAMPLERS, os volumes (LEVELs) dos DECKS 1 e 2, diminuíssem. e assim poderia destacar as vinhetas nos SAMPLERS
I have a wish.
It's something I've needed for a long time.
It would be great if you could sort sample banks into subfolders. Like it has been for a long time with both effects.
Because it gets very confusing when there are a lot of sample banks over time.
For example, you could then find beats, audio, or video banks more easily. That would be if you had folders in the list.
Best wishes, Dani
Yes I agree - and I'm sure it's been mentioned here before by a few of us.
Well the sampler has a few changes in the latest EA release - but still no way to organise banks.
Just one great big long list. Atomix, please can we have some bank organising features?
-BUILD 8439 (2024-11-24)
Sample banks can be grouped in subfolders
Whoopee! Lots of work ahead...
Oh hang on. You can't navigate to the folders with the previous/next buttons. The folder just gets skipped.
As it is, putting sample banks in folders renders them invisible/inaccessible unless you click on the sampler bank window (which you can't do from a controller).
Sampler 2 is not an improvement rather a deterioration !!
Well if prev/next would go through the full list including subfolders, it wouldn't be very useful, would it? :D
The idea is that you group by folders, then during a preformance you select (with the mouse) a bank in the folder you want, and then from the controller you can quickly scroll through the banks from that folder
can you explain why you think so?
It still seems very restrictive to me that if I create folders to organise my banks, I can't see or navigate (in/out) those folders from a controller.
I'm thinking it would be better now to just bundle samples into bigger banks, and switch to each set of 8 samples in those large banks from the parameter 2 controls.
Because even after many attempts I still haven't figured out how to use the samplers.
I had no problems with the old version!
Maybe it would be good if you made a video on how to use the samplers!!
I also think having to go back to the computer instead of having that accessible/doable directly from a controller is a step down/added work, especially if the controller can display the pad information on it directly.
Why was that considered as the default way to access? Could this be handled with a shift modifier while navigating pages?
groovindj wrote :
I can't navigate (in/out) those folders from a controller.
and how would you do that exactly, with just a + and - buttons on the controller?
If you want all your banks to be scrolled through with + and -, then just don't put them in subfolders.
92%
