The BACK button is not scrolling through the browser lists, but the FWD button works fine.
Should I copy the settings for FWD and change the values to - values.
Thanks.
Thanks.
geposted Fri 23 May 14 @ 1:28 pm
Just checked and all the values are set to -
So not sure what to do.
geposted Fri 23 May 14 @ 1:36 pm
What are the forward and back mapped to at the moment??
geposted Fri 23 May 14 @ 1:37 pm
Mapping for MC 6000 Mk1 not ideal. All about changes FX with Knob
geposted Fri 23 May 14 @ 1:54 pm
The default mapping in 8 for the back button is: var_equal '$mode' 1 ? sampler_bank -1 : var_equal '$mode' 2 ? deck default effect select -1 : var_equal '$mode' 3 ? nothing : var_equal '$mode' 4 ? var '$shift' ? deck left video_transition : video_transition_select -1 : var '$shift' ? sideview -1 : browser_window -1
If that value is not mapped or there is no value there, is it possible you are using a custom mapping?
geposted Fri 23 May 14 @ 1:55 pm
Thanks SuperAceMan
I have copied and pasted that in, and it now works fine. I had something very similar already in there, but I guess it must have been changed slightly.
I am running in custom mapping at the moment as I am making changes and want to test various settings. Thanks again.
geposted Fri 23 May 14 @ 2:22 pm
