Forum: Old versions
Topic: CDJ 400 plays on both players
I upgrade my system to Win 7 and moved from a motu sound interface to a Mbox Mini, and for some reason when configuring my CDJ400's is controls both players, the only way to switch is by pressing the eject button on the selected player to control just that player. I once had it playing where I didn't have to press the eject button. Any suggestions, I'm use VDJ Pro edition?
geposted Fri 23 May 14 @ 6:28 pm
first home gives you no controler support ;-)
second: works as designed
you can go to the controller section in v7 and select the player to a specific deck
