Topic: VDJ8 Broadcasting
Not working....if I follow the link given to me in the config page, I can see the little media player at the bottom of the page, but it gets greyed out after about a second...
I set it to do a direct broadcast. Turned off my Windows Firewall, and alo port forwarded UDP port 8000 on my router....still no luck..
What am I doing wrong ?
Thanks
geposted Sat 24 May 14 @ 7:09 am
Same here... I feel like beta-tester right now... for the full price :o/
I also have tried direct on 3 diff browsers(chrome, ff, and safari) on my mac and its not playing,
You folks seems having problems with VirtualDJ 8, may be your pc or your laptop having problems, thing is that I have windows 7 on my pc and I have VirtualDJ 8 and it is working well, broadcasting well, the sound quality is so clear and I have lots of listeners. I have still got the VirtualDJ 7.4.1 on my pc. The VirtualDJ 8 is new and lots of teething problem for you folks. I have choice to have the VirtualDJ 7.4.1 or VirtualDJ 8 to broadcast.
