Topic: Massive videoproblems!!!
geposted Sun 25 May 14 @ 1:49 pm
What is it you've pressed in the taskbar??
Is that the speaker tab that you just pressed? I tried and I could not reproduce. Just curious, what is VideoWindowAlwaysOnTop set to?
Edit: Nope tried that, and still could not repeat. I just noticed it's a .MOV, is this a PC or Mac?
Hello!
For the first time , sorry for my english , but I can not English well , I have to translate with Google. I hope it is to be understood halfway .
Yes, I have clicked the speaker tab . On a Windows 8.1. Intel i7 and a Intel HD Graphics 3000 and nVidia GeForce GT 555M . The error occurs with me with two graphics cards.
Hat on Saturday a live performance and was constrained to VirtualDJ 7 change because the VirtualDJ 8 crashed constantly . It was so bad that not even my Hercules Console RMX2 worked.
In VirtualDJ 7, there was video problems . As in VirtualDJ 8, there was initially no problems and after a few hours , spiked the video and then he pointed to the monitors to nothing. Only a reboot helped there.
In Virtual DJ 8 but went after some time the Hercules Console no longer . Taxes fell , but the master was no sound. I suspect that there was an ASIO driver issue. Only on the headphones was because something .
That's very very embarrassing when that happens during a wedding and people just danced.
VideoWindowAlwaysOnTop is set to 1, otherwise it will shows me the window ledge .
Greetings , Erich
Wanted to say. It does not matter where I click. As soon as I click on anything outside Virtual DJ, the monitor goes black and can then no longer start. Then I have to restart the whole Virtual DJ.
In Virtual DJ 7 which incidentally makes nothing.
Under battery options in control Panel , do you have that set at High Performance . Also have you tried this on another laptop yet . Does the same thing happen . It could be your HDMI port or even your cable .
hello, I can exclude. I have a second notebook of hp and has the same problem. the power option is set to maximum performance and the second pc cable is connected with another hdmi.
