Hi All
I made a post a few days ago, but it appears to be gone, cannot find it anywhere.
Anyone else find that Direct Broadcasting is broken ? Doesn't matter which browser ( IE,Chrome,FF )
I get this :
Cannot play anything - all greyed out.
I get this :
geposted Mon 26 May 14 @ 2:55 pm
will take a look at it , but might be related to inwards connection you your pc, aka blocked port 8000 from connecting to you..
But anyways, will take a look and test some here too
geposted Mon 26 May 14 @ 3:39 pm
I port forwarded port 8000 UDP and TCP to my Laptop from my Wifi Router, also switched off my Windows Firewall - issue persists.
geposted Mon 26 May 14 @ 3:44 pm
Try start broadcast ..
Then open this : http://www.whatismyip.com/ to find your IP.
In your browser, write http://your-ip-here:8000/listen.ogg
Can it connect ?
If not, keep broadcast going, and open this page http://www.canyouseeme.org/ enter 8000 as the port. Do you get success as results or error?
Can it connect ?
geposted Mon 26 May 14 @ 3:47 pm
However - I see that I cannot connect to it from my browser over the web....it works on my internal LAN on port 8000. So its definitely something on my router or ISP....
I did port forward the right ports....
EDIT !!!
I think the issue was because I tested from within my own network to the outside IP, and for that I had to enable LAN Loopback, because I'm connecting back to myself, I did this, and it then started working !
Thanks !
Anyone care to just confirm it is working from the outside please ??
https://virtualdj.com/broadcast/fjorko
Thanks very much !
geposted Mon 26 May 14 @ 4:30 pm
Works yes ;)
geposted Mon 26 May 14 @ 4:35 pm
Great!
Thanks !
Thanks !
geposted Mon 26 May 14 @ 4:38 pm
no prob ;)
geposted Mon 26 May 14 @ 4:51 pm
