Forum: Beta Builds Regression Bugs
Topic: Build 1814
Build 1814:
-Fix batch-analyze sometimes giving wrong bpm results
-logUnsuccessful searches works with CU disabled
-Fix renaming of virtual folders
-Files scanned in order when added to automix
Build 1810:
-Fix some more drawText crashes on mac
-Allow multiple decks to be output on a single channel
-Fix pop sound on cue
-Fix possible automix crash when video closed or reset
-Automix updates gain before mixing
-Fix slider draw crash in some skins when no external effects available
-Fix crash on some cameras on windows
-Fixes audio dropouts when changing samplebanks, probably other audio/video dropouts too
-Fix some possible crashes
geposted Tue 27 May 14 @ 1:35 am
CAMERA PLUGIN
My cameras worked in1785.666 but just a black screen now regardless of which skin used. USB or firewire camera connected.
Win 8.1 i7 8gb 7700 2gb card
Cannot confirm this.
Works fine here, with Asus Laptop Win7/ I5/ Nvidia GT 330M/ internal Webcam.
Camera stopped working for me awhile ago, not sure which beta. As stated before, it work right out of the box with original beta. Win 7, Sony DVI-D70 PTZ camera, Ion Video 2 PC MKll. Still works in 7, but not as good as it used to. It takes awhile to shut off, and freezes my screen.
Work fine on my Mac.
When automixing two 1080p videos get a split second stutter. Does not do it mixing manually. This is on a late 2013 iMac 3.2GHZ I5 27inch 1GB Nvidia GT755M graphics card home computer, haven't tried on my gig Macbook Pro.
I've been trying to test on and off since the first day of release. I've only had this software crash on me twice. Once was the first day during a karaoke song and the other tonight during video play. I do not usually play video files but I decided to give it a shot tonight to test out some of the effects. During my first "mix" of videos, going from deck 1 to deck 2, the software froze, crashed and then restarted. On reboot, the software started playing right where it left off, but my sound from deck 2 was gone. I tried every combo in the config that I could to get it back but ultimately had to manually shut the software down and reboot it. Deck 2 came right back on with sound.
I then tried the same video files again and had no problems this time. Played several others without any issues. Hopefully it was just a glitch but just thought I'd report it.
Forgot to add, MBP 13" late 2012 model, i7, 2.9ghz, 8gb RAM.
