I have just installed the Home version of VDJ8 and something very strange has happened to my display
Can someone please explain to me why the display is all in gibberish? How can I solve this problem? Many thanks in advance.
geposted Tue 27 May 14 @ 11:52 am
Can you check what language is selected in Config->Options ?
EDIt, hmm it seems that its not language related. Something is wrong with the fonts in your computer.
By default the 2 deck skin uses the Helvetica font , and if not available it would use the Arial. It seems that its not the case in your computer. Do you have an Helvetica font installed and if you do, can you properly type with it using a different application ?
geposted Tue 27 May 14 @ 12:18 pm
I don't think I have Helvetica installed, but I almost certainly have Arial installed. This seems very strange because I also have VDJ7 installed on don't have this problem?
geposted Tue 27 May 14 @ 1:25 pm
Could you try with a different skin, e.g. the VirtualDJ 7 one ? Or is the issue not related to which skin is selected ?
geposted Tue 27 May 14 @ 1:27 pm
Changing the skin hasn't made any difference I'm afraid.
geposted Tue 27 May 14 @ 2:14 pm
