Before I install Virtual 8 DJ, will version 7 still b on my machine so I have the option of using both. Thanks
geposted Tue 27 May 14 @ 2:56 pm
Yes both will remain and you can use both.
Some folders will be shared (skins, plugins etc). If you uninstall either version don't delete documents and settings as this will affect both versions.
geposted Tue 27 May 14 @ 3:00 pm
