Warning!!
is possible only if very slowly
test without Songs in deck
I can do video....
I can do video....
geposted Wed 28 May 14 @ 8:38 am
fast = crash
very smoothly = right
geposted Wed 28 May 14 @ 10:11 am
What type of crash are you seeing?
Windows Not Reponding?
Do you also get this using the default skin also?
geposted Wed 28 May 14 @ 10:17 am
WIN 8.1
yes.... Windows Not Reponding....
Test with Default skin
geposted Wed 28 May 14 @ 2:15 pm
Here is video http://youtu.be/NYeigPKvG10
geposted Wed 28 May 14 @ 2:27 pm
I'm having the same problem.
HP ENVY 14 2002ea beats
Windows 8.1 64 Bit
2.2GHz boost to 3.9GHz i7 Quad Core 2nd gen
8 Gig RAM
32 Gig Readyboost
AMD Graphics card 1 Gig dedicated
750Gig HDD 7200rpm
Windows 8.1 64 Bit
8 Gig RAM
32 Gig Readyboost
750Gig HDD 7200rpm
geposted Wed 28 May 14 @ 5:23 pm
Yep - i have tested also and can confirm.
Reported - thanks.
Reported - thanks.
geposted Wed 28 May 14 @ 5:40 pm
Mine works but I am also using Windows 7 , looks like there is some bugs with 8.1 and VJ still
geposted Wed 28 May 14 @ 8:42 pm
The bug was probably only present when the sampler was visible.
Will be fixed in build #1821
geposted Thu 29 May 14 @ 2:27 am
accepted ( only with sampler)
geposted Thu 29 May 14 @ 3:50 am
