When the skin rescale from 1920x1080 to 1280x800 the waveform is completely useless looks tiny, some screenshots with the same song:
VDJ8 waveform: 20.13.33.png)
Others programs waveform:
 20.05.53.png)
The fonts on the player also looks really small, like 5 pts a little bit blurry.
I have tried almost all available skins ... until today VDJ8 waveform is completely useless using 1280x800 resolution
VDJ8 waveform:
 20.13.33.png)
 20.05.53.png)
geposted Wed 28 May 14 @ 7:38 pm
Catap, what you posted here should indeed be in the Skins forums, as it will require a custom skin in 1280x800 if you need to get a lrger sized song position progress..
what i ve told you to post in this Forum was the pic you posted about the graphic glitch you get in Config.. so this one..
geposted Wed 28 May 14 @ 9:17 pm
