Forum: Beta Builds Regression Bugs
Topic: Build 1819
Build 1819:
-Fixes some videotransition plugins (mac)
-YUY2 support for Camera plugin (windows)
-Fixes Virtual Folders not stored some times
-Fix line endings on search log (windows)
-Fix renaming mp3+cdg files
-Fix SongPos shadow on high-dpi screens
-Fix possible skin panel crash
-Read track number from certain m4a files
-Fixes text display on Denon controllers (mac)
geposted Thu 29 May 14 @ 12:34 am
Renaming mp3+cdg files (reported by me) [solved] many thanks :)
All my virtualfolders has been lost from v7 to v8.
But i have to say that:
- I installed v8
- Then I made a backup of the new database
- After that I desinstalled v7, v8, and reinstalled v8.
I noticed that none of my virtualfolders survived.
Probably due to this process but maybe a bug for some other ones.
Scanned about 3400 mp4 video files. After it was done VDJ was very laggy. When loading a file it would take a lot longer than normal. When scrolling library it was very jumpy. Closed VDJ and reopened, everything worked normal. Late 2013 iMac 3.2GHZ I5 27inch 1GB Nvidia GT755M graphics card.
Please note that the purpose of this forum is to report things that worked in previous v8 builds but have stopped working in the latest build.
Sorry I was in the bad forum so.
im playing spot the difference like crazy here.. surely i'll find something soon besides the known cdg lag ..
I'm just finding out that with this build, I am unable to drag songs from my search into virtual folders on the Mac. I understand that at this time, I still cannot drag songs into the decks / virtual folders from an outside folder / window, but not I cannot even do it from inside the software. They still play when dragged into the decks.
Mac Book Pro 13"
i7
2.9ghz
8gb
10.9.3
Disregard, I shut the program down and re-opened and now it's working as it was before.
Update to build 1819. I try using the camera, but it only display ghost image.
Same I also upgraded to build 1819 and now Its green and it shows a double image of me lol , worked perfect in the last build
