Topic: BPM counter not accurate
The BPM counter is not accurate and I have noticed with many of my music files. VDJ7 was better and I was hoping for an improvement with VDJ8 but it is really worst.
geposted Thu 29 May 14 @ 5:16 am
Please provide more detail.
Is it a problem with doubling or halving of BPM?
Is the BPM incorrect by fractions or by whole numbers? How far out is it?
How are you determining the correct BPM? Did you time it yourself/use another software/read it from the web?
geposted Thu 29 May 14 @ 5:25 am
djxhalxPRO (OEM)Member since 2014
Well, I have 2094.902 build of VDJ8 and still, like 20% of the tracks, are analyzed wrong compared to VDJ7 database (which btw is analyzed perfectly 99.5% of the times!). It's really annoying, there should be some kind of re-analizing quality check for such cases. Mostly the BPM is wrong for like 70bpm up, or 30bpm lower than the usual BPM scanned in VDJ7. Is there any help for that?
geposted Wed 07 Jan 15 @ 9:10 pm
Can you give examples of tracks (names+artists) that are wrong, and what the wrong/right BPMs are?
That way others can compare/test.
geposted Thu 08 Jan 15 @ 2:58 am
geposted Thu 08 Jan 15 @ 3:05 pm
