Topic: Video out of sync
I've still got video and audio out of sync. Messed around with settings but I can't work it out. Perfect in VDJ7. Also getting video 'roll' horizontal line occasionally rolls up the screen.
Alienware mX17 laptop all specs well above recommended. Any thoughts?
geposted Thu 29 May 14 @ 7:07 am
I think this may be an issue. All of my videos were off as well. However, I went into the menu and added a -10 delay. seemed to help only slightly.
Never had an issue before... I'm well up to specs.
Also have this kind of problem but it is not on all videos. Some videos is out of sync like 2 seconds! Videos are ok in VDJ v7.4.1
Went back to VDJ 8 build1785 (The pre release) and the problem is gone.
Something was messed up in later versions. Tested build1828 and the out of sync problem was there again as well in the newest build1932 so the pre release works best for me. Sight...
Same here... hoping for a resolution.
@eclipseentertainers the posts above yours are pretty old builds i suggest you get the latest version and optimize your computer and see if that helps.
I have the latest build. I actually upated my video card drivers and ran all screens at native resolution and the problem stopped.
