My speakers are doing something weird.. It has been humming on the new laptop. I tried different settings until I unplugged the hdmi cable and the hum stops. My speakers have a ground button and it works on the small speakers.. I was wondering if there is a solution to plugging it into the master system at the bar.
geposted Thu 29 May 14 @ 2:52 pm
What are you running HDMI to at this bar?
geposted Thu 29 May 14 @ 9:27 pm
The display(s) that the HDMI cable is connecting to is causing a ground loop.
The solution is to use a ground loop isolator on your audio cable(s) - Please see https://virtualdj.com/wiki/Ground%20Loop.html
geposted Fri 30 May 14 @ 3:42 am
wow, here was the answer. the support from the laptop producer said " load the new drivers from the sound card start it from fresh and it will stop. It stopped instantly. Learn something new..
geposted Thu 14 Aug 14 @ 11:43 am
