i have an asus g2 laptop 3g's ram 256mb video card dual core 2.40 ghz windows vista service pack 2
32 bit os
when using a flatscreen tv to view my videos , they freeze up or lag behind the same with my karaoke
also i can't remove my clone files from the sidelist the only option i have is to( remove from virtual folder)
which in turn remove all my files from the existing virtual folder that they came from
32 bit os
geposted Thu 29 May 14 @ 7:46 pm
i found out that my video card needed to be updated it is working perfect
i just need help with the clone feature being able to remove virtual files from the sidelist without clearing out the files from
where they came from
also need help with mapping assigning effects to buttons
geposted Thu 29 May 14 @ 10:27 pm
You need to read the manual, it has a lot of the info on your topic of interest...
geposted Thu 29 May 14 @ 10:47 pm
