Hello All
I have two questions under options when you do restore to factory is there
a way not to do everything? Let's say I just wanted to restore broadcast
options. I would have to reset everything I set up. That could be a lot
and then remember everything the way I had it. I think it would be a good
idea to be able to do a factory reset but also be able to do it in
sections. Under the audio tab you can save settings is this just for audio
or does this save all your settings?
Thanks
Thanks
geposted Fri 30 May 14 @ 5:40 am
Factory settings usually means "blank" .. or more specifically as default for the software..
That being said, for both broadcast and audio settings you can pretty much do just what you said. .Both places you can save different configurations/settings, and easily have several settings available for audio and broadcast
(as well as the "auto detect" one for audio, should you want to try auto detect a new setting for audio)
geposted Fri 30 May 14 @ 7:53 am
right click on an item and choose "reset to default" just for this item ;)
geposted Fri 30 May 14 @ 7:58 am
