Topic: keylock?
I may be missing something, but when using TIMECODE, it doesnt appear the key lock always works. last night I played a gig with timecode and sometimes when I moved the pitch on my CDJ units really high or low, the key was unchanged like it should and other times, it acted as if I turned off key lock (but it was turned on). Any ideas? this was the first time I noticed this and only 2-3 songs did I notice...
geposted Fri 30 May 14 @ 10:48 am
Have you checked what pitch rage you had chosen? Some tracks if outside the pitch/BPM % will be ignored. I have mine set to 6% because things can get really hairy with the sound when there is a large difference in BPM %
geposted Fri 30 May 14 @ 10:55 am
Well I have the pitch range set to the same as my sliders on the CDJ 800's BUT there is a +100% button on the CDJ so I can go up and down up to 100%. on V7, when I went past the pitch range set in VDJ, the keylock still worked. in V8, it does not. I think the couple of songs I pitched down to like 15% did have issues..
geposted Fri 30 May 14 @ 10:57 am
