Forum: Old versions
Topic: HERCULES RMX MAPPER
I noticed there was a mapper for the Hercules Steel. I was wanting to see if anybody is planning on making one for the Hercules Rmx.
geposted Fri 30 May 14 @ 10:52 pm
The RMX is natively supported and should work without any custom mapping file required.
Do you have any issues working with version 8 and your RMX ?
The only issue I have is with the seek buttons. Before I was able to press the left seek button and it would go to the left of the browser(to the folders). Then if I pressed the right seek button I would be able to toggle back to the track listing within the folder. I'm no longer able to do that. The other issue I have which is not major is the LED light on the scratch button not lighting up when pushed for vinyl mode. It still performs the same function as before. However this just made it simpler to distinguish rather than having to look at the screen.
Both issues should be fixed now.
