Topic: Analyzing BPM
I scanned several songs and for some reason when songs are scanned the bpms are to high or right around 116 BPM. It doesn't match the true BPM if I use x2 or /2.
Also, when a song is rescanned, the BPM in the deck doesn't match the bpm in the column browser. For example, the song Used 2 had an initial BPM at 116. When I use tap beat, the deck showed 92, but the column in the browser showed 89.4.
I'm not sure if it is setting issue.
FLeX
geposted Sat 31 May 14 @ 8:04 am
