The faders in vdj8 do not respond with my Mixdeck Quad. I've been updating my vdj8 daily thru 5/26
geposted Sat 31 May 14 @ 11:20 am
Hi Greg,
One of the Hardware team will look at this soon and report back.
Thanks
Thanks
geposted Sat 31 May 14 @ 6:21 pm
Just to understand something here.. you see the faders moving on the screen but not alter the sound ? Or not moving at all on screen if you move them from the controller ?
What faders dont work ? Volume, EQ,Gain, crossfader ?
Windows or Mac ?
Other than that, the deck sides work properly ? Do you see the special button in the Audio tab of Config, and the unit properly detected by its name in the Controllers tab ?
Windows or Mac ?
geposted Sat 31 May 14 @ 6:46 pm
Windows operating system.
The only mixer function that works is the crossfader. The gains, eq knobs and 4 faders do not move onscreen or alter the sound. In an earlier update, the faders all responded until a track was loaded in one of the decks, but then would immediately stop. After one of the recent updates, the faders do not respond at all.
geposted Sat 31 May 14 @ 9:02 pm
another note: i am not hearing anything in cue. When I move the "cue mix" all the way to "cue", the cued song is extremely faint, even when the "cue gain" is all the way up. I believe i have it properly set up:
output - speaker + headphones
card - mixdeck quad
source:
master mixdeck quad chan 1&2
headphone mixdeck quad chan 3&4
card - mixdeck quad
source:
geposted Sat 31 May 14 @ 9:14 pm
Yes, the deck sides seem to be working properly.
geposted Sat 31 May 14 @ 9:38 pm
