Topic: not a huge issue but.... [Solved]
i used to use the brake funcion alot but since v8 its gone, there is a brake start but no brake to stop, will it be re added or am i missing something, otherwise its a pretty good update
geposted Sun 01 Jun 14 @ 1:03 pm
I believe its rampStopTime in settings.
cheers buddy ill have a play around and see if i can get something to play with
thats sorted it thanks for pointing me in right direction
Nevermind, I'm too late. Glad you found your answer.
the rampstoptime thing works great for me too :) thanks alot for the tip
