No you need to be much more specific, you WANT the trails to stop at some point, you don't want them to run forever.
why don't you have your controller up faders mapped to VDJ, you're asking for PFFX and not using faders, That's like demanding snow tires for your car but living in mexico
and if you're not using faders you don't want to use the volume effect you just want to kill the gain.
this is what you want.
cycle "POST" 2 & var_equal "POST" 1 ? effect_slider 'echo' 1 48% & gain 0 : var_equal "POST" 0 ? effect_slider 'echo' 1 0 & gain 0.5
prerequisites
the echo effect is on
the echo strength is set to 0%
restFXOnLoad in options is set to off..
This is meant for the active deck, you can do it per deck this is simple
What happens
you're playing a track, you press a button, the track mutes the trails start, then the trails will decay and repeat around 8 cycles, at which point you change track, press play and also you press the first button again so you don't get trails on your new track
Press on, press off
If you want longer/shorter Change the 48% to something else.
prerequisites
What happens
Press on, press off
geposted Thu 17 Jul 14 @ 3:34 am
well with the vci400 they are mapped, but my timecode setup is hybrid mixer and i dont use the software mixer. My mixer is better for scratch style hiphop djing, but it has midi also..![](/image/11763/141965/M70.jpg)
Also when i say dont stop, example the loopout plug in is a mimic of hitting echo and having those echoes trail until it fade out. So if i start the trails and quickly load a track it wont cut off the trails...listen to my FB friend and pay attention to the echoe trail and still load a song
See how at 1:50, 2:50, 4:20, 6:26 before the trails have stopped he has already loaded a song on that same deck...thats what i mean by the trails not stopping.
geposted Thu 17 Jul 14 @ 6:30 am
