I have a question about jumping from Cue 1 (Loop set as the first cue button) to Cue 2 (set as a cue point).
Have noticed that if Cue1 is set as a 4 loop, the Cue2 does repeat the loop even as a cue point.
I would like it to release the loop (Cue1) when hit Cue2 (set as Cue2) !
Any suggestions ?
Any suggestions ?
geposted Mon 02 Jun 14 @ 10:57 am
Not a bug
There are 2 ways how to do it depends on what you want
Method 1; Script for cue 2
'loop ? loop & hot_cue 2 : hot_cue 2'
Is a loop active ? Yes, turn the loop off and go to cue 2 : No, go to cue 2
There is also a option to stop the loop following the cue
'loopAutoMove' set this to no.
I'm not sure what will happen if you jump out of the confines of the loop, I think it just turns the loop off. ( if you jump forward it does, if you jump backward the loop stays where it is and will loop when the track gets back into the loop) this is probably your best option.
geposted Mon 02 Jun 14 @ 1:39 pm
okay but i cannot get my hot cues to work. hit hot 1 then hit hot 3 and its still bouncing around hot 1but not going to 2 or 3 stuck at hot 1 or around it.
geposted Mon 02 Jun 14 @ 9:17 pm
Thank you locodog, nice to see some quick answers ;)
Will try it out when I get home..
geposted Tue 03 Jun 14 @ 1:16 am
That worked great !
Thanks for the info loco..
geposted Wed 04 Jun 14 @ 2:08 am
