Hi!
I would like to ask how can i load my own samples like the old version where there was a load option in sampler tab? is there something similar in vdj8?
geposted Tue 03 Jun 14 @ 6:47 am
Find your samples in the browser then drag and drop,
If you would like the old style of loading put a request in the sampler wish list.
geposted Tue 03 Jun 14 @ 7:14 am
rightclick in the left Folder browser on to the samples folder icon . you can create a own ( custom) samples bank. create your samples e.g by choosing the master out panel in the default skin and record a own sample or just drag and drop a sample existing sample in the the new sample bank on the left. Your new sampler bank will be displayed on the sideview/ sampler like the default samples. when you added some samples you can also edit them by using the sampler editor...
greetz
rob
greetz
rob
geposted Tue 03 Jun 14 @ 7:41 am
