Forum: Old versions
Topic: Sampler audio question
Hi,
I want to play video samples while audio-only tracks are playing. I'm using an external mixer so two outputs, one for each deck. How do I stop the sampler from outputting audio?
Thanks,
Matt.
geposted Tue 03 Jun 14 @ 12:24 pm
You can assign a sampler_volume action to a custom knob, then turn it down.
Alternatively you could edit each video clip, unselect the 'audio' button then save the sample (long winded).
You need to use the sampler editor and then you can disable the audio track in the sample.
Like wise if you had a video sample only wanted the audio you can disable the video section.
Page 72 of the User Guide ;-)
I've done the custom knob thing and that's what I wanted :)
Actually, I tried the above and it doesn't work :(
First I tried the custom knob on deck 1 with sample_volume and turned it all the way down but I could still hear it so I did the same on deck 2 and can still hear the sampler.
What am I doing wrong?
Here is a workaround..
Assuming that you are using a USB sound card with only stereo outputs (routed to your external mixer) and no 3rd channel mixer...
add a 3rd line to your Audio setup.. so have ..
deck 1 ... as you already have it
deck 2 .. same.
deck 3 ... use your computer built in sound card ... Chans 1.2
Then from the Sampler Options choose to output the sampler to deck 3 ;)
