Forum: Old versions
Topic: VMS2
bogartPRO InfinityMember since 2004
With VDJ 8 the VMS2 will not load tracks when hitting the load button for respective deck.
Does it need to be mapped for VDJ8, and if so how to map so you can load tracks from,
automix, browser as in version 7?
geposted Tue 03 Jun 14 @ 1:35 pm
In addition I now cannot get the audio setup correctly.
Audio setup as: speaker+headphone
Source (First way ) Master channel 1&2
Headphone channel 3&4
Did not work correctly, changed to:
Source Deck 1
Headphone 3&4
Both ways only work for a short while then no sound.
Also when I get sound from deck and load deck 2 sound cuts off.
Anybody have the correct setting please?
Thanks
geposted Tue 03 Jun 14 @ 2:16 pm
You should be able to see a "special" button in the AUDIO tab of Config, with an icon of the VMS2. If you click on that button, and then hit APPLY, it will auto-create the correct audio setup for you , which is Deck 1 .. VMS2... Chan 1,2 / Deck 2 .. VMS2.. Chans 3,4
Nothing is really changed for the mapper, so it should have almost the same functionality with version 7.
Make also sure that the unit is properly detected by its name in the CONTROLLERS tab of Config and the factory default is selected in the mappings drop down list.
geposted Tue 03 Jun 14 @ 4:05 pm
Initially that is the way I did it;
I am going to delete everything that's there now and retry.
Thanks
geposted Wed 04 Jun 14 @ 6:05 am
Just re installed VDJ8. Sound worked correctly this time.
However, I still cannot load tracks from the browser.
geposted Wed 04 Jun 14 @ 11:08 am
The LOAD buttons of the VSM2 dont work ?
geposted Wed 04 Jun 14 @ 4:55 pm
Everything works fine with version7, just not with 8.
The only way I can load tracks using the load button on VMS2 is
if I put tracks in the automix section.
geposted Wed 04 Jun 14 @ 6:44 pm
Thats a bit weird.
the 2 x LOAD buttons (mapped simply as ..load) should load the focused track on the Browser to the decks.
If they only work when a track is in the Automix list (in Sideview), then maybe the Songs list (middle), doesnt have the focus when you press the LOAD button ?
Can you check your Loadsecurity setting (in Config->Options) ? Even if it set to Yes, it should still pop-up a confirmation if the deck is playing, but worths trying with No.
geposted Wed 04 Jun 14 @ 8:18 pm
That did not work.
However, I found something else about making a new folder called device.
Then copying the mapper into that folder. Don't have time to do a complete
test, but so far the load buttons seem to be working as they should.
Thanks
geposted Thu 05 Jun 14 @ 7:55 am
Just did a test and it still does not work. The only way to load from the
browser is the (scroll) button in the center. [That is the one between the up & down
side to side arrows.]
Just hooked VMS2 back to my main system and everything works fine.
Any other suggestions?
geposted Fri 06 Jun 14 @ 10:41 am
If it works on one system (computer) and not to another one, there might be a chance that one of them is using a custom mapping file with incorrect assigned action for the LOAD buttons.
geposted Sat 07 Jun 14 @ 1:51 am
Reverted once again back to factory mappings for VMS2.
In version 8 I can now get tracks to load from browser. I now have to use keyboard to move to playlist (automix)
section in order to load track. When loading track from playlist, but it does not remove it.
In version 7 load track from browser okay. When I load from playlist it removes track from playlist section.
Should it not have the same actions in 7 & 8?
geposted Sat 07 Jun 14 @ 9:06 am
Tried version 8 on another laptop with the VMS2.
Same results. VMS2 works with VDJ version 7.
Does not work correctly in version 8.
Version 7:
Can load from browser.
Can load from playlist and removes track from playlist.
Right and left arrow buttons mapped to move from folders to browser to playlist and sidelist.
Version 8 .
Cam load from automix(playlist) but does not remove track.
Right and left arrows do not work as mapped.
Mappers should carry over from version 7 to version 8, or is that wrong?
geposted Tue 10 Jun 14 @ 12:54 pm
Nothing is changed for the Navigation buttons on the VMS2. Still the Left and Right NAV buttons should set focus on the Folder and Songs Lists.
Are you sure you are using the default factory mapping and not some custom one ?
As for the non-removing tracks from Playlist (automix), yes that is how version 8 works now. You can try to use the Sidelist instead of the Automix list and set the RemovePlayedfromSidelist option to Yes. This will remove the files from the sidelist once played (get the played flag)
geposted Thu 12 Jun 14 @ 12:52 am
Ther is also an option to remove played songs from automix (hidden in the panels options I think).
About the nav- buttons: had this problem with Hercules RMX. The mapping was simply wrong (or other than required).
Thats the factory-mapping:
left: browser_folder
right: browser_window 'songs'
changed it to:
left: browser_folder ? browser_folder : browser_window -1
right: browser_window +1
Works well for me.
geposted Thu 12 Jun 14 @ 1:05 am
The option for the automix list is to remove the tracks only if played with Automix function.
geposted Thu 12 Jun 14 @ 1:09 am
djdad
Is there a way to map the load key to remove it from the automix without messing
up the rest of the settings?
Right now I use the automix as the playlist (like in 7) and the sidelist for requests,
which is set to horizontal.
I did try a mapping to load and remove (after trying original mapping): but this screwed up some
of the other settings.
Thanks
geposted Thu 12 Jun 14 @ 8:59 am
