I recordnized that some buttons are not working on the Vers.8
With this tread i want to inform Mixtrack Quad users how to handle with it.
Sync:
The left sync button sometimes does not respond:
Try to press on your controller shift & sync at the same time.
If sync does not work on both sides or only sometimes, so because the master channel is switched on. try to deactivate master channel ( by click on your skin )
Browser scroll is not working:
may there is a small scriptbug in the mapper config that avoids to scroll the tracks.
I resoved the prob by mapping it in the cofiguration interface by insterting the
Key: BROWSE
Action: browser_scroll
ok, thats all for now
if other Mixtrack Quad users found new bugs or bugsolutions you are welcome to use this tread.
Sync:
Key: BROWSE
geposted Tue 03 Jun 14 @ 6:21 pm
