HI
i am using macbook pro 13 retina with 8gb ram and i5 cpu and flash hard drive
when i am using virtualdj 8 the cpu is 50% all the time (not only when upload a track)
the fan is starting also and its eat the battery
that is normal ?
that is normal ?
geposted Wed 04 Jun 14 @ 3:00 am
No...there is a issue somehow...
CPU Usage and Mac´s getting hot, is a known issue that is being already reportet.
geposted Wed 04 Jun 14 @ 3:38 am
this is not possible to work this way! the computer is getting too hot and i have to work with another software
sometimes virtualdj8 is shutting down during work
i cant believe i am paying for virtualDJ8
guys you have to fix it !
geposted Mon 09 Jun 14 @ 3:38 pm
See this thread and check if it's the same thing on a mac. Not a real solution but probably at lease one of the reasons.
https://virtualdj.com/forums/189832/VirtualDJ_8_bug-report_Forum/Constant_Skin_redrawing_eating_the_CPU.html
config/options/skins/maxSkinFPS. Try 5, 10, 15, instead of 30 and see if it helps. I had to turn it down so my machine would not overheat. They need to fix it.
geposted Mon 09 Jun 14 @ 4:22 pm
