Forum: Old versions
Topic: Reloop Terminal Mix 8
Reloop Terminal Mix 8 is now natively supported in version 8
Available with builds ending at .680 or higher (simply let the software running for a few minutes to silently update the controllers definitions and relaunch)
A quick guide will be available soon.
geposted Wed 04 Jun 14 @ 3:36 am
Thanks to team!!! Works perfect till now, still testing. i had some issue with autoupdate but as i disconnect myself and log again, it update automatically. Good weekend to everyone.
la version 7.4 de virtual entonses no es compatible con reloop terminal mix 8?
No, Terminal Mix 8 is not supported in version 7, and probably will not be.
Please post in English next time, or choose the Forum with your native language https://virtualdj.com/forums/
It would be really nice if you made it compatible. Mainly because Vdj8 won't be out and fully stable for a while. So people like me are taking big chances by running Serato on PC or Virtual Dj 8 at a gig, since none of those are fully stable. Vdj is PC friendly and Serato is Mac friendly.
Vdj 8 reconoce la controladora tm8 pero hay un retraso al momento de colocar play, modifique en opciones pero sigue habiendo una diferencia, si alguien sabe porque sucede favor explicar ya que otras controladoras de menor valor funcionan mejor,gracias
