Topic: Slicer effect. - Page: 2
The actions should simply be ... slicer 1 to slicer 8 and slicer 'step' +1/-1 and slicer 'length' +1/-1
No need of percentage values or _effect_button actions. Keep it simple.
Well you learn something new every day, that'll be a hard ingrained habit to break.
how would you put that in and where in the box picture on page 1?
im new to mapping...... very new
exsample : MODEB_SHIFT_PAD1 :
and how many for the diffrent steps and legths
cause for now the slicer just loops 1 beat stutters it ,,,, the song continues but only with the stutter then when released it picks up where songs is present, it dosent continue with the full audio in the background
that's how it works.
It samples a passage into slices, and the slices can be recalled,
to control the dials/sliders
MODEB_SHIFT_PAD1 : slicer 'step' +1
MODEB_SHIFT_PAD2 : slicer 'length' +1
MODEB_SHIFT_PAD5 : slicer 'step' +1
MODEB_SHIFT_PAD6 : slicer 'length' -1
i have 8 shift pads for the sampler ass well.. how would you put the lengths and beat parts in? as i have 8 slicer pads ,,,,,, but only 8 pads for beats and lengths combined
so what abouthte other pads? ? i mean the ones u dont mention in the above thread just now
pad 3,4,7,8? and so far this havent changed anything in how it works?
all i can do is 1 beat loopp over and over again when i press it down,
the other slicers i see does the loop but the actual audio keeps on playing in the track ass well,
again sorry to bother
i have seen the lengths parts working somewhat, but maybe i should just tryand post a pic of the settings in the menu?
THAT'S EVERYTHING
Open the GUI and pay attention.
EASY FOR YOU TO SAY :)
im trying hrd to make it work slicing like in the varoious videos i have seen, but i can only get it to loop , though i try and change the lengths and steps and dosent so anything all 8 pads do the excat same thnig the is really the thing that confuses me
Screenshot of your mapper first.
Also screen capture video with the gui open, (not a phone video)
here it is, i know it needs work i just dunno what and how
For MODE B just use these
After that, no matter what, it's done.
i actullay allready tried that excat setup... andi could only use 1 beat and itsliced ,,,,,but i could not hear the original track in the background, or is this just impoosible to do cause other controllers can do this type of slicing.
98%
