That:
Syphon Native video output
Like serato :)
Like serato :)
geposted Thu 05 Jun 14 @ 6:43 pm
geposted Thu 05 Jun 14 @ 6:49 pm
I'm using it but sometimes it close my VDJ, when I change the source in resolume :(. Maybe it's not handling errors.
geposted Thu 05 Jun 14 @ 11:35 pm
Ok - i'm going to move this to the Plugins forums - as the wish has been granted.
Then hopefully the developer maybe able to address your issues.
geposted Fri 06 Jun 14 @ 8:23 am
Thanks ! Awesome !
geposted Fri 06 Jun 14 @ 9:06 am
Walk me through the process that causes your issue and I will investigate :)
geposted Fri 06 Jun 14 @ 9:13 am
Hi, I'm using mac and have problems installing syphon for VDJ 8 , can you please describe the install process.
best regards,
Martin
best regards,
Martin
geposted Sat 28 Jun 14 @ 10:46 am
Hey, SBDJ, when I active plugin and use it in resolume, if I disable it & activate again, drop my VDJ with this error.
If I choose or use another effect works good, but if I enable & disable it, this fail.
Process: VirtualDJ [457]
Path: /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
Identifier: com.atomixproductions.virtualdj
Version: 8.0.0 (8.0.1855)
Code Type: X86-64 (Native)
Parent Process: launchd [141]
Responsible: VirtualDJ [457]
User ID: 501
Date/Time: 2014-06-28 23:47:00.006 -0400
OS Version: Mac OS X 10.9.2 (13C64)
Report Version: 11
Anonymous UUID: 0AFDCAD5-5649-FC01-F646-0BF21CC81235
Crashed Thread: 8 CVDisplayLink
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
VM Regions Near 0:
__TEXT 0000000106c77000-00000001083eb000 [ 23.5M] r-x/rwx SM=COW /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
User ID: 501
Report Version: 11
VM Regions Near 0:
geposted Sat 28 Jun 14 @ 11:00 pm
Try v1.2 and see if that is any better :)
geposted Mon 30 Jun 14 @ 5:22 pm
So much better, have you fixed the drop. Thanks so much! working like a charm
thanks and congratulations for your work
geposted Tue 01 Jul 14 @ 7:08 pm
