Hello Fellow VDJ Users.....In need of some help finding a script to map a keyboard key to toggle between the different skin panels in VDJ 8 such as Audio Mixer, Scratch Mixer Video Mixer and Master Mixer. I Was able to find a script for this in VDJ 7 but the same script will not work for VDJ8. Below is the script for VDJ7. Thanks for your help in advance!
VDJ7 Script for toggling Skin Panel:
skin_panel "mixer" ? skin_panel "scratch" & skin_panel "mixer"select : skin_panel "mixer" & skin_panel "mixer" select
Thanks, Eddie
Thanks, Eddie
geposted Fri 06 Jun 14 @ 2:54 pm
This will work:
skin_panelgroup 'mixer' +1
geposted Fri 06 Jun 14 @ 3:41 pm
THANK YOU DAN!......YOU DA' MAN!.....I've gotten so used to using this Script in VDJ 7 for Adding Cues, Etc with a Larger Waveform That I felt Something was missing when I started using VDJ 8!
Thanks Again!,
Eddie A
Thanks Again!,
Eddie A
geposted Fri 06 Jun 14 @ 6:00 pm
related,,,,i want a script to toggle to mixer view when keyboard shortcut is pressed(not held down), and change to scratch view when pressed again. the above script just cycles through the 3 panels....i want to switch directly to only two panels.. mixer and scratch.
geposted Wed 10 Aug 16 @ 12:03 am
use the action learn button in the mapping window to learn the panel names
consult
virtualdj.com/wiki/VDJScript Examples Database.html
and look at
Switch between the default wave & scratch wave
right at the bottom, combine what you have learnt.
consult
and look at
geposted Wed 10 Aug 16 @ 12:10 am
thanks man!!!! needed a little push :P
geposted Wed 10 Aug 16 @ 12:15 am
another thing...the script i am using is also mapped to switch between two other panels...and it is intefering with the other script...how do i "separate" two scripts...when i use "&", it just inteferes with the other script...do i use brackets or something like that??
geposted Wed 10 Aug 16 @ 12:29 am
Again
Look at what it does, checks if one panel is visible, if it is it gets another panel, if it isn't it gets the panel queried.
That's the script you want to switch between 2 panels, just put your panel names in
locodog wrote :
consult
and look at
right at the bottom.
consult
and look at
geposted Wed 10 Aug 16 @ 12:55 am
