Topic: Virtual DJ 8 & Pioneer Controller
Just want too make sure. Do I need to login each time to Virtual DJ 8 in order to use the Pioneer controller? If so, occasionally I work at venues that staff does not know password/or Internet is not working.
Thanks,
Craig Mivshek
granddjentertainment
geposted Sat 07 Jun 14 @ 1:08 pm
Login once. If you don' use a second computer or use the logout button in config/licenses the computer is activeated.
If you use 2 machines ensure before you go to a gig that you can start the software.
It only will deactivate if there is internet and you used the other computer meanwhile. If that happens just relogin to reactivate.
Greets, Heiko
Thanks !
