Forum: Beta Builds Regression Bugs
Topic: Build 1834 - Page: 1
-Fixed saving samples that are encoded in an uncompressed format
-Fix translation for root elements not working correctly
-Auto-gain still applied when fake_gain is used
-Missing folders in VirtualDJ documents folder recreated on startup
-User fields in filter folder can work both numeric and string
-resetKeyOnLoad option added
-New v8 'Text' video effect
-Sample editor mouse cursor getting stuck on mac fix
-videoFPS config option used (should reduce cpu/gpu usage)
-Improved visibility when moving position of items in list
-Fix 'deck master fx_slider' type of actions not working correctly on controllers
-Some missing translations added
-Fixed storing of order when playlist opened in sideview
-Fixed negative time display
-Fixed crash when doing fast scratch on loop boundaries
-Selecting the same effect in 2 slots will always load the same instance now
-Some small scratch wave optimizations
-Fix analyzer marking karaoke songs as regular music files
-Small rhythm wave performance improvement
-Fix possible crash reading corrupt mp4 tag
-Don't enumerate ._ mac metadata files
-Fix possible automix glitches with pitchQuality 2
geposted Sun 08 Jun 14 @ 5:39 am
Any news with PC-to-PC streaming bug on Mac? VDJ crashes on client connection..
geposted Sun 08 Jun 14 @ 7:36 am
Euhh!! Is it just me? Since 1828 and with 1834, I don't see the Camera plugin anymore!
geposted Sun 08 Jun 14 @ 7:56 am
Working here (PC) - are you looking in the Virtualisation Folder ???
geposted Sun 08 Jun 14 @ 8:28 am
effects > autostart
what can i use this for??
geposted Sun 08 Jun 14 @ 11:42 am
Camera plugin still does not work with Capture cards
geposted Sun 08 Jun 14 @ 12:09 pm
Jakovski, do you mean "visualisations"?
I can't find my camera plugin! I tried to re-install vdj8, but still not here! (When I have re-installed vdj, I kept my settings)
geposted Sun 08 Jun 14 @ 12:38 pm
Camera is not available on XP.
geposted Sun 08 Jun 14 @ 12:45 pm
Yeah, I get the same thing, but different values.
geposted Sun 08 Jun 14 @ 12:54 pm
Camera not available on XP! Whouah!
So, if I want to use it, I have 2 solutions;
- buy 2 new PC
- keep using VDJ7 (I prefer that)
It's a little bit strange, because with the first releases of VDJ8, the camera plugin was here.
Is there a plan to bring camera plugin back on XP?
geposted Sun 08 Jun 14 @ 1:31 pm
AsTheDJPRO InfinityMember since 2008
The Pitch Reset she you reset the pitch now the waveform and BPM shakes there not smooth any more.w/wo controller RMX2
geposted Sun 08 Jun 14 @ 1:55 pm
Text video effect not workong at all :-(
geposted Sun 08 Jun 14 @ 2:46 pm
Working good for me. But that is the dilemma, some effects are working for some, but not for others. I'm sure, they will get it right. By the way, I'm on a PC.
geposted Sun 08 Jun 14 @ 3:20 pm
Sorry forgot. PC ver. Win 8.1, Lenovo Idea tab y500, i7, 16 gb Ram, 2x nVidia GeForce 650m in Sli.
Regards Tomas.
geposted Sun 08 Jun 14 @ 4:32 pm
now on beta 1834 the timecode vinyl is getting worst beside the calibration problem in the beginning of the tracks now in the middle of the track (song) when i scratch now it skips.it was not doing that before.
geposted Sun 08 Jun 14 @ 4:40 pm
Hello, folders are in disarray, as it should appear on the disc are ...
geposted Sun 08 Jun 14 @ 8:47 pm
scrach work, saturates the master channel ...
bpm engine, not block songs recorded live, which you see in the picture, takes 148 bpm, and the engine reads it to 194.67 bpm ...
geposted Sun 08 Jun 14 @ 8:48 pm
Please remember that this topic is about regression bugs only!
To use the v7 Camera plugin in v8, you can rename Camera.dll to Camera2.dll and it should show up in the list again.
AMAHM: Could you post the number you get with the camera plugin as well? Thanks
geposted Sun 08 Jun 14 @ 10:52 pm
Thank's Adion,
It works now for the camera plugin on xp.
geposted Mon 09 Jun 14 @ 5:45 am
39%
