Forum: Old versions
Topic: Mapping another controller??
lapenaPRO InfinityMember since 2007
I have AKAI APC40 and since this is MIDI mapping controller I wonder if I can use it with VDJ to trigger some FX or move the knobs etc. I'm not sure how VDJ works with supported controllers but I guess is by MIDI mapping.
Have one of you guys try to use a controller that is not supported by VDJ? and How do you map it?
Thanks!
geposted Sun 08 Jun 14 @ 5:05 pm
geposted Sun 08 Jun 14 @ 5:24 pm
Thanks I download it, seems to work but there is not documentation on how to do your own mapping. The crossfader not work, only to crossfade video but it doesn't the sound. Any one has a worked version of the mapping out there? and some explanation on the commands?
Thanks!
geposted Sun 08 Jun 14 @ 6:10 pm
I make it work, but still you can move either the Video Crossfader or Regular Crossfader. wonder if there is a command to move both crossfaders?
geposted Sun 08 Jun 14 @ 6:50 pm
I think you have to link the video & audio in VDJ, not in the mapping.
geposted Mon 09 Jun 14 @ 10:03 am
