Please can some time be spent on correct the problems with the beat grid. as the next step. it need to be precise for loop and effects, right now auto loops are virtual impossible. Also Having to stop the track to set downbeat must be fixed. Can the Bpm and CBG editor be embedded into the man song position, this is one area you should research what have become a standard use and implementation of editing.
CAn the tag editor be embedded in the info panel, actually the best place for it, makes the panel actually productive.
Actually most of the editors can be embedded into the Skin and side panel. Eases work flow when having to edit things unexpectedly.
can i have thoughts from the dev team on how this sounds to them.
geposted Mon 09 Jun 14 @ 10:42 pm
Just having the editors 'pop up' within the footprint of the browser would be a start, actually 'panelising' them might be too much as this wouldn't allow resizing.
geposted Tue 10 Jun 14 @ 5:17 am
Im finally understanding, with the joys of different skins, is it possible this function prevents some common stream lining? Is this why most softwares with some editors embedded only have 1 skin with some variations of that basic skin?
geposted Tue 10 Jun 14 @ 3:04 pm
