Topic: Auto mix issue
On vdj 7 you could load a bunch of tracks into automix and then remove one track at a time if you decided not to play it. I am not finding that option in vdj 8. It only offers the clear all option when you right click on a track in the automix folder. Please add that option back, or tell me how to only remove one song without clearing all the songs out of the automix folder.
Thanks,
Jay
geposted Tue 10 Jun 14 @ 10:32 pm
Right click on a track, in automix, and select remove. It's the last option. Make sure that all the tracks are not highlighted. I just tried and it works.
Or simply select the track and press <del> on your keyboard... ;-)
