I have a custom mapping for my Quneo, But I just can't get it to light up. Does anyone know what the problem could be?
Here is my mapping:
<?xml version="1.0" encoding="UTF-8"?>
<mapper device="Quneo Custom" author="Me" description="Quneo Custom" version="740" date="10/06/2014" priority="-10">
<map value="0-CC71" action="deck 1 level" />
<map value="0-CC72" action="deck 2 level" />
<map value="0-CC73" action="deck 3 level" />
<map value="0-CC74" action="deck 4 level" />
<map value="0-CC121" action="crossfader" />
<map value="0-12" action="effect "beatgrid" active" />
<map value="0-13" action="effect "FlippinDouble" active" />
<map value="0-14" action="dump" />
<map value="0-15" action="slip_mode & on 1" />
</mapper>
Here is my mapping:
</mapper>
geposted Tue 10 Jun 14 @ 11:42 pm
I basically want the effects to stay lit up when they're active, not just the instant I press the button. All the faders work fine.
geposted Tue 10 Jun 14 @ 11:44 pm
You will need to create a proper definition file, and define the Leds properly, if you need the Leds to work. https://virtualdj.com/wiki/Controller_Definition.html
Simple MIDI will only offer buttons and sliders.
The unit is already pre-mapped for version 7 (and should also work with version 8 too), however you will need to Pro License for this.. https://virtualdj.com/addons/15999/Quneo.html
geposted Thu 12 Jun 14 @ 12:58 am
