Topic: DDJ-SZ Ringleds
Sometimes the ringleds on the jogshuttles are running AFTER loading a track and it is still in pause/stop.
This can be reproduced by touching the jog wheel on the ddj-sz or on the screen OR put the needle on certain possition on the song.
geposted Wed 11 Jun 14 @ 2:30 pm
Yes we are aware of the issue. the DDJ-SZ will be updated soon with more functionality and some fixes. We will let u know shortly.
Wann kann man damit rechnen?
The mapping files are already prepared to properly support all the Leds of the jogwheel, but you will have to wait for the next updated build as there was something that had to be added in order those to work as they should.
We will let you know. Wont be long
thanks for the info ...
