Hello, I come from the Spanish forum and many users say the same about that shadow in the wave track. Please could remove it or give instructions to do so. It is very confusing to see where the beat falls to mix with that shadow that hides the wave. Thank you.
       geposted Thu 12 Jun 14 @ 7:47 am
          +1 for that, it's only cosmetic and it's a hindrance.
    geposted Thu 12 Jun 14 @ 9:52 am
          Yes please remove it... or option to turn it off. I always think I'm at a mix point in the song when I look quickly
    geposted Thu 12 Jun 14 @ 10:05 am
          i like it as it is for sure.. gives a bit of texture, and looks better on the full color waveform spectrum ;)
As well as making it easier to see the spot
But could maybe be optional ;)
geposted Thu 12 Jun 14 @ 10:15 am
The reference line is good, the problem is the shadow. If you look closely, hidden wave and seems to be a point of slope, what as known as djs mixing point. It removed or added as an option to remove it.
Thanks and regards friends.
geposted Thu 12 Jun 14 @ 10:31 am
          The dev team is extremly busy 24h, 7days a week...bugs and crashes have major prior at the moment, cosmetic minor...
so let´s have a solid base, walls and roof before we talk about the curtains...;-)
geposted Thu 12 Jun 14 @ 10:39 am
It is true and you are right, no trouble with this but it is a contribution for their consideration. Greetings.
geposted Thu 12 Jun 14 @ 10:48 am
          agree...but as norway mentioned:
could maybe optional...;-)
geposted Thu 12 Jun 14 @ 11:05 am
          Wasted programming for something no one wants, no one asked for.  Yea, I keep thinking the break is coming!  Accuracy/functionality over looks any day!
    geposted Thu 12 Jun 14 @ 5:31 pm
          I just want to add that this shadow issue is more than just cosmetic. Some people have implied that since it's cosmetic, it should be put on a distant back burner. True, matters like the software locking up are more urgent, but this is in fact a matter of usability and does deserve attention at some point. It should be relatively easy to allow the OPTION for simple waveform shading without the shadow, like previous versions. There are many ways in which VDJ8 is more difficult to use than VDJ7, and this is one of those.
    geposted Fri 13 Jun 14 @ 3:06 pm
          I agree, I think the policy is 'fix what we can when we can' so I guess it will make the cut soon  If possible, V7 aspects should be saved and optional, if a perceived improvement is implemented.
This being one of them another being the limiter.
geposted Fri 13 Jun 14 @ 3:45 pm
          Completely agree with your comments. Thank you for supporting this issue that at first glance is just cosmetic, however it is important to remove that shadow that fools the precision of the cut. Regards
    geposted Thu 19 Jun 14 @ 9:23 pm
          I agree on the shadow, I keep thinking a quiet part of the song is coming up.  What I would like to see is the part of the song that has been played, maybe dim it a bit.  I'd almost say have it turn grey so there is a distinct difference, but someone may still want to see the color.
    geposted Sat 21 Jun 14 @ 9:04 am
          +1 on removing this shadow :) Thanks!
    geposted Sun 22 Jun 14 @ 3:05 pm
    geposted Sun 22 Jun 14 @ 6:32 pm
    geposted Sun 22 Jun 14 @ 6:55 pm
          +1.
As mentioned before, it does fool you into thinking you are coming up to a quiet bit of the song, and makes it a bit more difficult to see the actual track.
Also appreciate that the dev team have other important things to work on at the minute.
geposted Mon 23 Jun 14 @ 4:00 am
          +1
it should be just a single line with an opposite colour to the waveform colour (for example using inverted colours).
for example something like this could be good: http://oi62.tinypic.com/20aezp4.jpg
geposted Mon 23 Jun 14 @ 9:46 pm
    geposted Mon 23 Jun 14 @ 9:54 pm
          Even though i do believe that looking at the shaded needle of the song position (progress bar) makes you think that a silent part is coming up, i cant really believe that you are using the song progress bar as a mixing tool. Its there to show 2 things. A rough song structure and the current playing position (helps you see at a glance if the tracks reaches the end etc). The size/width that the progress bar has in almost all available skins, is really not that handy to get details on what is coming up on the next few beats.. A detailed report of what is coming in the next few seconds/beats is what the rhtyhmwave and the scratchwaves show on the top.
Do i miss something here ?
geposted Mon 23 Jun 14 @ 11:17 pm
