Forum: Old versions
Topic: Tag Errors
I seem to have some tag errors with respect to title and artist listing together under title.
Is there an easy way to fix this?
Is there a way to ripp cd's through the program to hard drive?
Is there a way to scan and list BPM besides one at a time through play back?
Is there a way to adjust the cross fade speed, it is too fast, there isn't a transition it just slams a to b or b to a.
Great program BTW, it is my 4th one and it rocks.
Rick
geposted Fri 26 Sep 03 @ 2:08 pm
LOL, VDJ can do all of this, read the manual to find out all it can do for you.
For Tags, VDJ don't read mp3 tags but create title and author with the filename (correct filename should be: "Author - Title.mp3")
But if you want to use ID3 Tag (v1 and v2) you can add the Virtual DJ ID3 tag parser to VDJ.
You can find it in the effects download page:
https://virtualdj.com/addons/view.html?type=effect%20plug-in
if u want to just correct your file, there is a software called mp3 collector, this will correct all your file and name them the way u want them, it will also change the tags for you and name them correctly
See Ya
djchicago
Chikago,
Got a link? Thanks for the reply. My tags are intact, they have title and song without a space causing them to read as one under title.
Rick
Ran 2 gigs this weekend with this-COLD-! Ran perfect, love it!
