Topic: Reset the Order
When I open VJ8 and go to my playlist , and say I click the Top 40 playlist I created , well it puts it out of order , so every time I have to click Reset the order. Is there something in Options to fix this , or is this a bug ..
geposted Fri 13 Jun 14 @ 8:44 am
did you set savePlaylist to "yes" ?
Yes playlist is set to yes
maybe this will be solved by the next update....
