Forum: Old versions
Topic: Rolled timestretch (Working with numbers)
I keep getting number based ideas that are too complicated for VDJ to handle so I can't really get a grip on using numbers, this one I'm sure is possible....
Rolling timestretch, initiated via action poi's from a silent track
If the track to be affected is at quartz lock it's easy
Action POI: deck 1 pitch 0.25 [8 beats later] deck 1 pitch 0.5 & deck 1 goto +16
How would I do it for cases when not at quartz lock, I suspect it involves a couple'get's, 'parameter divide' & a 'parameter multiply'
geposted Fri 13 Jun 14 @ 9:18 am
24 hour bump, with added clarity: All I need to know is how to 1/2 the current pitch.
pitch -50%,
*Facepalm*
