Topic: Files gone
Today and found about 6 files that said "missing files".
Went to relocate and results said could not locate. I tried to locate on drive
outside of VDS and they are completely gone.
I used the same files yesterday and did not delete any of these files.
Don't know if anyone else has had this issue.
geposted Fri 13 Jun 14 @ 9:59 am
Actually maybe,
I've lost a few albums but thought it was my own carelessness and it wasn't an issue because everything is backed up.
Have you searched the recycle bin, windows?
Technical is there a M$ windows log for files being deleted that can be checked.
For the 1.5 hours I used VDJ8 before crashing I had the same issue. Files that were there 2 days ago weren't there last night. Strange... I didn't have any time to investigate as It crashed before I had a chance to look at what was going on
Yep checked the recycle bin, and everywhere else.
Gone!
If you played it completely, this will register on your History!
How about previous versions of the folder containing? right click the folder>properties,>previous versions
