Topic: DDJ-SX Related Bugs
TBathePRO InfinityMember since 2007
I just installed VDJ 8 today, and so far I've noticed the following bugs when using with the Pioneer DDJ-SX unit:
- 3 FX knobs at the top do not function properly
- The sampler volume control does not work as it should, it seems there are fixed volumes that override it, and haven't been able to find a way to toggle it to use the volume of the sampler level instead
Not sure if there are settings / mappings that aren't configured correctly to make these work or if its a known bug. Other than that, awesome new release!
geposted Sat 14 Jun 14 @ 4:39 pm
