hi, i have little problem problem with audio options in virtual dj8. In 7 is very easy setting (pre-set 4.1).In 8 its very different and if i set master to channel 1,2 and headphones to other i dont hear any sound(yes,i press cue button) but the music in headphones is same like master.
Thx for help
Tom
Thx for help
Tom
geposted Mon 16 Jun 14 @ 12:24 pm
In the MASTER center panel make sure the Headphones MIX knob is at 0%
If that doesnt work, you could try to set your soundcard to Quadrophonic mode. See here.. https://virtualdj.com/wiki/Pre-listening%20with%20headphones%20with%20Sound%20cards%20without%20ASIO%20drivers.html
geposted Wed 18 Jun 14 @ 3:00 pm
thx for help,its working now :)
geposted Mon 23 Jun 14 @ 11:49 am
