Topic: 3 crashes so far today...
nothing but crashes as I try to activate both camaras,internal web & external using the freeframe pluging .I had allowed the 1834 build update.something told me this would mess up what I had working...not even seen build 1848 yet...will try a different order to bring these two to work...
geposted Tue 17 Jun 14 @ 9:08 pm
crossfader quit on the xponent.I thought i went through this before and it was a crossfader setting deleted (or not saved) after the crash...hmm
hmm not sure I had stepped on the power supply which in turn was connected to a loose extention cord,causing a quick short,the system kept running but the crossover stopped.I think that it might had caused a spike killing something.I allready looked inside but it looks allright...Im getting a replacement pronto..
replacement on its way!...complete with gig bag,though I would like to replace the torq logo on the bag with a virtual dj logo.this is like a cloth patch thing.anyone makes em?
